COLOR CHANGE QUESTION........ - NCRS Discussion Boards
  • Marc N.
    • August 31, 1998
    • 97
    Good morning to all....whanted to ask your opinions. How much ($$$) does a color change affect the price of a midyear?
    Re: COLOR CHANGE QUESTION........
    To a buyer who wants it the correct color, by the amount necessary to re-paint the car.
    • Roy B.
      • February 1, 1975
      • 7044
      or replace the trim tag with a repro like some do!
      • Tom S.
        • March 1, 2004
        • 1087
        I would say about 7-10k.That is what half way decent paint job will cost you.I just had one looked at by a bodyman friend. The differance in the prices are because he doesn't know what he might find after he gets started. Tom
        • John S.
          • September 30, 1997
          • 263
          Tom,
          The going rate for a good paint job is more like $15-20K, or higher, depending on where you live.
          • Tom S.
            • March 1, 2004
            • 1087
            I haven't heard of any that high here.But this is still small town America so to speak.Like I said I have a friend that has his own small shop, maybe he is giving me a deal?But 15-20k seems a little ridiculous! Tom
            • Phil P.
              • April 1, 2006
              • 409
              tom ,yes 15 to 20k sounds high but,this is what i got for 15k---pre-inspection after the body was removed---paint removed to glass---3 small areas of glass work---bond seams cleaned and reworked to ones desire---doors hood conv deck fitted 3 times---choice of laq,bc/cc---body left to out-gass for 6 months prior to prime---all body lines sharpened up---this work is/was done in a 1 man shop that does vets only---30 + years of vet painting and knows every curve and dip in a vet body---i've seen and own one of his 15 year old paint jobs and they look like the day he finished---of course he lives in big town america and needs $$$---phil
              • Tom S.
                • March 1, 2004
                • 1087
                For a body off job of that quality I don't think 15k is bad.When I said 7-10k I was refering to a body on good quality paint job. Tom
                • Norris W.
                  • December 1, 1982
                  • 683
                  I thought the current crop of replacement trim tags were easily detectable???
                  Wouldn't a car with a detectable repopped trim tag be worth less than an original in the wrong color?
                  • Dick W.
                    • 10483
                    You can always repaint a wrong color car correctly, but if the original trim tag is gone, the value has taken a significant hit.
                    Dick Whittington
                    • Dennis H.
                      • September 30, 2005
                      • 226
                      "body left to out-gass for 6 months prior to prime"
                      For the life of me I don't understand why this is a requirement other than to turn a normal paint job into a 1 year turn around. Did GM out-gas these bodies before painting?
                        "Did GM out-gas these bodies before painting?"
                        Nope! But, their objective was to 'make it' through a 12-month/12000 mile warranty period vs. build a Mona Lisa. AND, they ate a LOT of post production warranty claims on fit/finish....
                          In the St. Louis Paint Shop, the body was baked for 60 minutes at 280*F after first prime, baked again after sealer and first color, baked again for 30 minutes at 140*F after final color, and final-baked again for 45 minutes at 250*F. That's how the solvents were driven off - forced outgassing.
                          • Verne Frantz
                            John,
                            Do you know if that process was only used at the "fiberglass" plant or if it was also used at the "steel" plants?
                            Verne
                              Verne -
                              The "steel car" process was similar, although the bake temperatures were higher. First prime bake was 30 minutes at 390*F, primer-surfacer was baked for 45 minutes at 285*F, first color oven was 10 minutes at 200*F to "set" it for wet-sanding, and the final reflow bake was 30 minutes at 325*F.
