What is the back set on a GM KO wheel??
Plan to take KO off car and run after market 60 style Al rims, 7" X 15", however noticed the back set is 3 1/2" while the stock steel rim was 3 1/4". When I had the rear tires mounted on the KO they fit ( 225-70 ), but no extra space. So before I mount the 225-70 on the new Al rims would like to verify what the back spacing on the KO are.
YES, the 225-70 is a bit large and if I replace them the size would be lowered to the 205-65 which is what I run in the front. (Street Use)
