C1 2x4 Fuel Filter housing leak - NCRS Discussion Boards
  • Art B.
    • 333
    The fuel filter housing on my '57 has a slight leak as evidenced by some gas when I run my finger between the top of the housing and the glass bowl. I have tightened it as much as I dare. Any suggestions? A leak there could be disastrous
  • Mike M.
    • May 31, 1974
    • 8396
    Re: C1 2x4 Fuel Filter housing leak
    its usually due to mis-alignment of the bowl to housing gasket. mike
      Other considerations...
      The other 'top two' reasons for GF-48 filter assy's to leak are:
      (1) The pot metal lid has warpped due to prior use, heat, and over tightening. Check by laying the lid against a flat surface...
      (2) The outer gasket is old/dried and unable to properly absorb the mating surface edge differential(s). Remember, the purpose of a sealing gasket is to absorb surface differences across a thermal expansion RANGE. So, over tightening is just as bad as under tightening! The seal has to 'breathe' as surfaces expand/contract....
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Over time, I have been given two thoughts...
        ...on the subject.
        1. Try using 2 gaskets.
        2. Apply a film of lube to gasket surface.
        And, of course, what Jack & Mikie say...
