Exhaust Bolt question - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Posting this on behalf of new member RPOL36 who just joined NCRS and asked me to post his question:
    "Hi, I just joined the board and I own a 68 convertible 427/390 4sp built D07. The exhaust manifold bolt kit from Paragon matches some of the ones I took off which I assume are original since they match the head mark Paragon said was correct.
    However, the stud bolt on the drivers side is different from what I took off the car. My question is which is correct? the old one I took off or the plain stud one Paragon sent me in the kit.. I attached a pic to this post: the top/rusty one is what I took off, the one below it is from Paragon. Which one is correct?
    PS: this car is a power steering car I think that relates to what type bolt was used here according to Paragon. Also, where on the drivers side does this one go? I think its the first bolt from the front on the drivers side, correct?
    thanks!"
    Kurt
    #26406
  • William C.
    • May 31, 1975
    • 6037
    Picture is dreaded "red X" *NM*
    Bill Clupper #618
    • Kurt B.
      • July 31, 1996
      • 971
      Re: Picture is dreaded "red X"
      I tried but I don't know how to post pictures. I entered the URL but must have doen something wrong.
      I am certainly no Bill Gates when it comes to computers
      Kurt
      • Kurt B.
        • July 31, 1996
        • 971
        Here is the URL for the picture of the two different studs.
        Not sur eif this will work
        Kurt
        • Dick W.
          • 10483
          I believe that the old stud is the correct one
          Dick Whittington
          • Kurt B.
            • July 31, 1996
            • 971
            Dick,
            I had the same one on my smallblock and that is why I also thought it was the correct one but didn't know if maybe the big block motors used different studs.
            Kurt
            • Michael W.
              • April 1, 1997
              • 4290
              I thought the picture looked familiar
              http://forums.corvetteforum.com/show....php?t=1733240
              • William C.
                • May 31, 1975
                • 6037
                I vote for the old one with the flange.
                Bill Clupper #618
                • tom444634
                  Re: Exhaust Bolt question
                  Kurt,
                  I also went through the same thing. I have the same picture! The shouldered one is the original from my 71 LS5. I used 15 Paragon bolts and put the original stud back in (with some antiseize).
                  Tom
                    • 43221
                    Kurt-----
                    Run a NEW 3/8-16 nut BY HAND down the threads (long end) of BOTH studs and tell me how it goes with each.
                      • 43221
                      Addendum
                      Kurt-----
                      Also, you can and should thoroughly wire brush the threads of the old stud prior to running the nut down BY HAND. However, DO NOT run a die, thread-cutting or thread cleaning, on the threads.
                      • Phil P.
                        • April 1, 2006
                        • 409
                        joe do you suspect a china bolt ? *NM*
                        • Brandon Thompson
                          Re: Addendum
                          Hey, I'm the owner of the 68 with this question kurt was nice enough to post it since I wasn't able to get signed on here but I finally got the profile working!
                          Ok so sounds like the one I took off is correct...I cleaned it up and plan to re-use it where does it go I think it is the first bolt back from the front of the engine right?
                          the other bolts in the kit match what I think are originals I took off the double circle hex heads.
                          I also am still a little un sure about what I should do about lock washers, french locks, or no washers etc.. I'm not sure what is correct.
                          I want to go the correct route on that also and this is for a D07 build date 68 4sp 427/390 if any of that info is needed..
                          I was told the bolts could be locking bolts??
                          thanks!
                          • Geoff C.
                            • May 31, 1979
                            • 1613
                              • 43221
                              Re: joe do you suspect a china bolt ?
                              PHIL----
                              No, not at all. I'm just trying to confirm if it's an original stud. More info on that after we find out the answer to the question I posed.
