C2 hardtop rear window SS trim - NCRS Discussion Boards
  • Dick G.
    • May 31, 1988
    • 681
    I began the assembly of my rear window SS trim at the center bottom working my way out towards the upper part of the window. At the corners, every time I snap into the first clip for the outer trim, the small corner trim will lift on one edge. I have carefully bent the edge inward to help hold the upper trim with always the same result. Are some of you starting at the top working your way down? Any tips? Thanks DG
