C3 Fender Side Louver Restoration - NCRS Discussion Boards
  • Christopher J. Bunsey
    I am going through the assembly manual for my 1976, and it says that inside/behind the opening in my side louvers should be painted black. Can anyone give me any guidance on how/where to paint, and what kind/finish of paint should I use? How do you mask it off? Any guidance and/or pictures would be greatly appreciated!
    Chris
  • Michael W.
    • April 1, 1997
    • 4290
    Re: C3 Fender Side Louver Restoration
    All body panels visible from outside the car should be painted body colour. The opening itself should appear to be a 'black hole' by ensuring that all inner surfaces are covered with blackout paint. The paint is no different than used elsewhere in the engine compartment. Keep in mind that the body was not on the frame when this operation was completed.
    • Tom R.
      • June 30, 1993
      • 4099
      Chris:
      After 1973, workers used a sponge and stuffed it from within the engine compartment in the cove to minimize paint overspray inside the engine compartment. When the body got to the blackout booth, a small spray gun was used to "quickly" shoot the cove from the outside. Any overspray was wiped off and later polished. This wasn't neat nor precise and if you've studied enough original cars, you'll understand the method used and described. You can see a mix or blend of primer and blackout.
      Not a surprise, novice paint restorers don't understand the factory application methods with Corvettes and by studying the coves, one can identify paint overspray in the coves on these later models that easily underscores a repaint body from an original paint job. We catch it way too often...and I do chassis!
      A couple of paint types commonly reference include both the Krylon 1613 and the Deere "Blitz Black". I use the Blitz black. Hope this helps.
      Tom Russo
      78 SA NCRS 5 Star Bowtie
      78 Pace Car L82 M21
      00 MY/TR/Conv
        I really appreciate the insight...can you share your insight when it comes to doing the wheel wells? I want to do those too! Many thanks!
        Chris
        • Tom R.
          • June 30, 1993
          • 4099
          It was a quick shot and all those I've seen essentially cover the fiberglass with what can be seen...nothing fancy. Eye level and down.
          Tom Russo
          78 Pace Car L82 M21
          00 MY/TR/Conv
          • Bill E.
            • April 1, 2003
            • 200
            Chris, I looked into doing the well wheels on my '74 awhile back and found some good info in the archives. Bottom line, it was not very precise. Bill
              What did you search? What type of paint did you decide to use, and would you use it again?
              Thanks!
              Chris
              • Bill E.
                • April 1, 2003
                • 200
                Chris, check Archives under "wheel wells" and select "all terms". You should also check the Technical Information Manual & Judging Guide for your car under "Wheel Wells and Splash Pan Area". The Manual for my '74 has a good discription of the undercoating and black-out application. I haven't done mine yet, it may be a project for this winter. Bill
