follow up to 70-77 rocker moldings - NCRS Discussion Boards
  • Jeff W.
    • November 1, 2005
    • 272
    I contacted Ano-Brite, Inc. in North Hollywood, CA and they will re-annodize these. Depending on how much damage is done to them, it will run in the $500 to $600 range. Their web site is www.anobrite.com and he lists himself as the "King of Trim". I am looking to do mine this winter.
    Thanks to all for the help.
    Jeff
  • Jeff W.
    • November 1, 2005
    • 272
    And by the way....
    The set of service replacements went for $810 on e-bay last night, no tabs!!!
    • David D.
      • 330
      Re: And by the way....
      Jeff, Take a look at eBay item #190151332292, an original RH rocker molding with tab and 190151336029, a LH GM replacement rocker molding without the tab. Picture's show the difference between them. Dave
      • Jeff W.
        • November 1, 2005
        • 272
        Dave, Thanks, I do know the difference. I have the ones with the tabs on my car. The problem has been finding new ones with the tabs, hence the desire to find someone to refinish them. I can get the repo' without the tabs for less than $300 and they go last night for over $800.
        • David D.
          • 330
          Jeff, I figured you did know the difference, I thought it may help others, reading the post, actually see the difference between an original and a replacement or reproduction 70-77 rocker molding. Dave
          • John S.
            • September 30, 1997
            • 263
            Jeff,
            Dr. Rebuild has LH NOS Moldings for $250, so if you buy the original one on e-bay, you can have a nice set for $450-500 and still have your original mouldings.
            • Jeff W.
              • November 1, 2005
              • 272
              John, This is where I almost messed up originally. Just because it is NOS does not mean that it has the tab. 1974 was the last that the tabs were made by GM. They continued to make them without the tabs until 1980. The question would be does Doc's have the tab or are they service replacement.
              Once again, it amazes me how much I have to learn about these cars. Thats the fun, as long as it doesn't cost me a bundle in the learning process, but thats where you guys come in. Ask first, right?
              • Vincent F.
                • August 31, 2006
                • 202
                It will still cost you A bundle
                • Dave B.
                  • April 30, 1984
                  • 248
                  Jeff...Try
                  a phone call to Richard Fortier at 810-750-1472. He has my '66 rocker moldings right now.
                  Dave
