63 driveshaft restoration - NCRS Discussion Boards
  • jim cear
    Anyone know of someone for driveshaft balancing and restoration? I didn't see any ads in Driveline. Thanks
  • Donald T.
    • September 30, 2002
    • 1319
    Re: 63 driveshaft restoration
    Quanta restores driveshafts. I don't know if they will balance them, so you may have to ask them.
      • 43260
      Jim-----
      Quanta offers the service or, at least, they used to.
      As far as just balancing goes, most driveline service shops will have that capability. Spicer-franchised shops which carry the names "Driveline Service of [name of city]" I've found are especially good places to go for this service.
      As far as restoration goes, I don't think that anyone can actually restore the as-original surface finish of the extruded tube used for driveshafts. Quanta's service merely turns down the driveshaft tube section in a lathe to remove a small amount of metal, leaving "fresh steel". That's not how the driveshaft originally appeared, though. Even then, the "fresh steel" must be "maintained" by the application of some sort of clear coat or the more-or-less regular application of a product like Pre-Lube 6.
      • Terry B.
        • August 31, 1999
        • 607
        Jim,
        I had my drive shaft and half shafts restored by Greg Gorniak. He is an NCRS judge and restorer. He was able to bring them back to the original extruded look with no cast grey paint. No paint was used at all. He was able to give the color rainbow back on the welded areas too. They have not rusted either after a year on the road. I highly recommend him. Reasonable prices too. You can contact him at: red65vette@hotmail.com I will try to post pictures later.
        Terry Buchanan
        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
        Corvettes Owned:
        1977 Coupe
        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
        2003 Electron Blue Coupe
        2019 Torch Red Grand Sport Coupe
