68 Front Rotor & Hub Runout - NCRS Discussion Boards
  • Don Schuette
    On installing a new set of front rotors with the original hubs, one is right on for runout, and the other one was out over .014. On swapping sides, I found that the rotor is okay. I then put the dial indicator on the outer edge of the hub, and this is where the .014 out-of-whack is coming from. I checked my main nut for bearing loseness, and all is fine there. In calling Stainless Steel Brakes Corp., I find they don't make/sell the taper shims anymore.
    Does anyone still sell those? Or, do I have to get a new or used hub. If I need a new hub, can/should I just have my old bearing races pressed out and use them with the old, good-looking bearings or should I just use new races and new bearings?
    Any ideas on where to get inexpensive new hubs?
    Don Schuette #34493
    • 15601
    • John Hames
      Re: 68 Front Rotor & Hub Runout
      Can't you bolt the rotor to the hub then take it down to have it turned? I may be wrong, but it sounds like you put it on right outta the box. I did my front brakes that way and had no problem.
      • Rob Brainard
        Don, Take the hub to your local parts store that turns rotors, have them drive out the studs and true up the face of the hub [like a rotor, only one side]. Reinstall the studs and put the hub back on the car, check for runnout - should be OK! Been there before!!!!
        • Brandon K.
          • April 1, 1997
          • 474
          Don, Rob is right on with his solution. I've been there and done that too! Much cheaper than a new hub (which may have the same problem, anyway).
          BK
          • Don Schuette
            Brandon & Rob:
            Thanks for both your like suggestions. A friend of mine owns a brake & muffler shop and this cleared up the problem.
            Thanks again,
            Don
