rear end #s - NCRS Discussion Boards
rear end #s
  • Vincent F.
    • August 31, 2006
    • 202
    rear end #s
    Can someone identify this, AB W 229 1
    What year year and make would this be from.
    • 43202
    Re: rear end #s
    Vincent-----
    The "AB" identifies it as a 3.70:1 Corvette positraction differential used from 1971 to 1975. It was manufactured at the Warren Gear and Axle plant on the 229th day of one of those years and on the first shift. The actual year of manufacture can be determined by checking the casting date on the carrier case.
    • Vincent F.
      • August 31, 2006
      • 202
      Re: rear end #s
      Joe where would I find that casting date exactly thanks for responding
        • 43202
        Re: rear end #s
        Vincent-----
        It's on the left (driver) side of the carrier right above where the strut rod bracket mounts.
        • Vincent F.
          • August 31, 2006
          • 202
          Re: rear end #s
          Joe I think I found casting date,reads D180 .What does this refer to
