68 Turn Signal Lever/stalk - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    It's been a long time since I have had the steering wheel off, so I can't remember if I can tighten up the turn signal lever/stalk on my steering column without removing the steering wheel or if the wheel must come off to access the screw that holds the signal lever. Mine has loosened up slightly and I would like to tighten it down.
    Thank you in advance for any input,
    Kurt
  • William C.
    • May 31, 1975
    • 6037
    Re: 68 Turn Signal Lever/stalk
    Wheel off unfortunately.
    Bill Clupper #618
    • Jim T.
      • March 1, 1993
      • 5351
      Put some lock-tight on it.
