C3 Dash Lights Not Working - NCRS Discussion Boards
+ More Options
Posts
  • Ray Jackson
    My 70 C3 the dash lights just quit today. The Headlights work, the courtesy side of the switch works but not lights to the speedo,tack, or any of the center cluster. Is the reostat portion of the switch bad? I think I just need to replace the switch? Any Help would be appriciated
    Ray
    Re: C3 Dash Lights Not Working
    HL switch has a built-in circuit breaker that features 'driver warning' in the event the tail lights are shorted out and dysfunctional. You suddenly lose dash lights to WARN you your rear end is un-illuminated.
    BUT, if this were the case (easy to check, get out and see if you've got rear lamps), your complaint would be slightly different. You'd be telling us your dash lights 'mysteriously switch off, then come back on for a short period of time before cycling off again)....
    First, check your panel lamp fuse to make sure it's good. When that checks out and the rear lamps are operating, it's time to suspect the HL switch. Yes, it could be the dimmer section is history (wouldn't be the first time that area of the switch failed) or it could be the built-in circuit breaker is history...
    • Louis T.
      • July 31, 2003
      • 282
      Jack,
      I had never heard of the neat safety feature you describe. What years had it (in the headlight switch or anywhere else)? Thanks.
      Louis
        • 15606
        GM has a long history of this "safety feature." I had a 1964 Chevelle with it and I just found out my daughters 2006 Malibu Maxx has the same "feature." This may be the only similarity in the electrical system in thaose two vehicles other than they both operate on 12 volts DC. I suspect this feature predates the Chevelle significantly,
          The 'feature' goes WAY BACK (into the 50's) and is generally mentioned in the owner's manual, the shop manual or both. It's no secret...
          • Eric F.
            • June 30, 2003
            • 319
            Yep, my 56 Cadillac has it too!
