Question about changing striker in door jamb on 70 - NCRS Discussion Boards
  • Dennis Voiro
    Hello All,
    I need to replace the striker in the driver side door jamb on my 70 Coupe. Is this simply a remove, replace and adjust sequence or do you need to gain access to the inner panel?
    Your help is appreciated.
    Dennis
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: Question about changing striker in door jamb o
    The striker bolt screws into a captured nut on the body frame; access to the quarter panel should not be required.
    • Dennis Voiro
      Thank you Chuck, appreciate the response.
