Tri-Power Intake Bolts - NCRS Discussion Boards
  • Michael B.
    • June 18, 2007
    • 400
    I purchase a set of correct intake bolts for my 1969 L68 Big Block. The set included 14 plated bolts with shouldered heads and 2 non-shouldered bolts of slightly longer length. I assume these non-shouldered bolts were used at the left front along with the lifting bracket. The Tri-power engines did not included these lifting brackets from the factory.
    My question is, were these non-shouldered bolts used without the bracket or should I use 16 shouldered bolts. Or maybe my assumption is wrong and these bolts were used at the ignition shielding bracket locations. Anybody know?
  • Graeme B.
    • October 23, 2007
    • 213
    Re: Tri-Power Intake Bolts
    Hi Mike,from what i have read ,when the lifting bracket was taken off thick washers were put in place.Hope this helps. Graeme from OZ.
    • John C.
      • January 1, 2005
      • 616
      Mike
      My 68 tripower has two non-shouldered bolts where the lift bracket was taken off. Mine have a TR head mark but I'm sure many others are possible. They also have a .1 inch thick washer added. The addition of the washers is shown in the 68 AIM.
      John
      • Michael B.
        • June 18, 2007
        • 400
        Thanks John. I thought as much but I just wanted confirmation.
        Mike
