63 trans - NCRS Discussion Boards
63 trans
  • Joe C.
    • April 30, 2001
    • 126
    63 trans
    Does anyone know what the numbers sequence on a correct trans should say? I am looking to purchase a 63 trans and I want to know what the correct serial number should read-- thanks for any help.
  • William C.
    • May 31, 1975
    • 6037
    Re: 63 trans
    What is the vin of your car? Muncie or T-10?
    Bill Clupper #618
    • Harry Sadlock
      Re: 63 trans
      Joe, the last 63 that I have seen with an original T10 was VIN 14396.
      Just to help
      • Verne Frantz
        Make that latest 14647. ......so far *NM*
        • Harry Sadlock
          Re: Make that latest 14647. ......so far
          Verne, you car?
          • Philip C.
            • December 1, 1984
            • 1117
            14,019 FI with muncie *NM*
            • Verne Frantz
              No, just research. Thank Wayne Loran *NM*
              • Nancy charles
                Re: 63 trans
                need your serial # .
                • Joe C.
                  • April 30, 2001
                  • 126
                  Re: 63 trans
                  its a muncie- I don't want to post my serial number- its a roadster- appox 9,000 number. around jan car.it has a number on trans but I'd like to be sure its correct- what is it suppossed to have there- just vinnumber?
                  • Joe C.
                    • April 30, 2001
                    • 126
                    Re: 63 trans
                    its a municie I believe, but I want to know if there are other numbers pevious to vin number on trans. like month etc-
                    • William C.
                      • May 31, 1975
                      • 6037
                      Re: 63 trans
                      Should be a T-10 in a car that early, also the '63 Muncie was a 1/2 year only trans with a different case and tailshaft from later years.
                      Bill Clupper #618
                      • William C.
                        • May 31, 1975
                        • 6037
                        Re: 63 trans
                        Muncie has build date for the trans stamped on the side, T-10 has build date stamped and casting dates on main case and tailhousing.
                        Bill Clupper #618
                        • Wayne M.
                          • March 1, 1980
                          • 6414
                          First of all, let us know what maincase # is
                          Joe, in order for us to narrow down what Muncie you have, give us the part # (top row on the pass. side) For 1963 MY, it should be 3831704 (top line), with PAT. PEND. on second line. From an actual '63 Corvette trans, the VIN derivative stamped on the driver side rear edge is 3117522, and stamped on the rear bottom corner of the shifter cover flange is the assy date, P06 06.
                          For 1964 and 1965 Muncies, the maincase top # is 3851325, with early '64's having the Pat. Pend. and later '64 cases (and all others into the '70s) having US Patent No 3088336 on the 2nd line.
                          1966 and '67 cases will have top # 3885010.
                          So let's start there and see if we can help identify your Muncie.
                          • Joe C.
                            • April 30, 2001
                            • 126
                            Re: First of all, let us know what maincase # is
                            Thanks for you help-- the trans has the following numbers 3831707 & 3831704, then on the tail it reads 3831731, and by the side plate it reads PO122- Is there suppossed to be a vin number on the side of trans? and is it just a vin number or does it have other numbers? my vin is 30867S109... THANKS FOR ANY HELP.
                            • Harry Sadlock
                              Joe, as stated above for a 9XXX car one would expect a T10 Trans.
                              If it were a T10 it would be something like WA231 3109XXX.
                              If your staying with what you have then the VIN derivitive would be 3109XXX.
