327 Cubic inch engine - NCRS Discussion Boards
  • Ray Durand
    Hi ,
    I'm hoping someone can help me in identifying the year of this engine. 327 cubic inch
    Engine block casting no. 3849852, under this number the clock points to number 3.
    1- What kind of seal is at the rear main of the crankshaft? Part # ?
    - A cord type?
    - or a 2 piece rubber seal ?
    2- I am also looking for the part number of the re-seal kit for the Transmission which should include;
    side cover gasket, front cover gasket, 2 x rear cover gasket, 2 x seals, 3 x O-rings for the shifter linkage.
    Transmission # F03I8DE
    Thank you for any assistance,or if you can point me to someone who can help me.
    Ray Durand
    NCRS #45725
  • William C.
    • May 31, 1975
    • 6037
    Re: 327 Cubic inch engine
    Unless Mortec is wrong, it's a 283 used in '64-65, two piece seal. You don't say if you are talking 3 or 4 speed, Muncie or BW four speed, but most any parts houls can get the gasket set, or they are available via eBay regularly.
    Bill Clupper #618
    • David D.
      • 330
      Ray, It is not a 327 engine. 3849852 is a 283 block, "DE" code is 195 hp with Powerglide, out of a 1965 or 1966 Chevelle. Small journal block wih 2 piece rear main seal. The casting date is on the opposite side from the block casting number. Dave
