C-3 trailing arms - NCRS Discussion Boards
C-3 trailing arms
  • david ferragamo
    C-3 trailing arms
    My 68 convertable is getting better all the time new coils and front shocks are in, new leaf spring is almost in. I was going to send the trailing arms to VAN STEEL in florida. The arms themselves are rotted a little,so i was going to by new arms and have them rebuild the the rest including the struts. I was hoping to get some feed back about VAN STEEL. thanks dave f.
  • Robert T.
    Infrequent User
    • March 1, 1980
    • 16
    Re: C-3 trailing arms
    I have used Van Steel for more than 27 years. I have had very good results with them and the quality of their wook is exceptional. I had the trailing arms on my 67 done back in 1980 and they have performen flawlessly since. (I drive it between 2000 to 4000 miles per year). I have probably put about 50 sets on cars over the years and have had no reported failures.
    • William C.
      • May 31, 1975
      • 6037
      Bair's is another good choice. They supply many of the major Corvette houses.
      Bill Clupper #618
      • Dick W.
        • 10483
        I will second Bair's. Yogi and Brian are very easy to work with and their work is second to none!
        Dick Whittington
        • Jim T.
          • March 1, 1993
          • 5351
          David one difference of using Van Steel or Bairs is that with Bairs doing the rebuild/replacement, your brake discs will be riveted to the spindle just like 65-82 Corvettes left the factory.
          • George D.
            • August 31, 2000
            • 225
            I have used Van Steel for rebuilding trailing arms, steering box, and the rear end on my 69. They have done top notch work. Art Dorsett is the person I have been dealing with over the years.
              • 43242
              Dave-----
              You can't go wrong with either Van Steel or Bairs. Also, I strongly support your decision to replace the trailing arms. If there is any "rotting" evident on the arms, you can almost bet that there's even more that can't be seen. It's absolutely foolish to try to salvage arms which have ANY evident rotting. These are components that you want to be absolutely solid.
              • Anthony S.
                • April 3, 2008
                • 183
                Dave,
                We are doing a rear suspension rebuild on a friend's '74 454, using t-arm assemblies from Van Steel.
                My friend opted for an exchange using rebuilt t-arm assemblies. Turns out the axle flanges were not included w/ the rebuild, they had to be transfered (what a p.i.t.a.) from the old assemblies.
                The same thing happened to another friend who did a t-arm exchange through Corvette Central.
                p.s......Make sure the t-arms are drilled for a rear sway bar if you have a big block.
                Just a little FYI.
                Good luck,
                Anthony
