I found a replacement Holley fuel bowl for my stripped rear carb.I bought the bowl through JEGS and is very close in apearance to the original bowl.Thanks for your help!!
67 3x2 fuel leak fixed!
Re: 67 3x2 fuel leak fixed!
Rich, glad to hear you got your fuel bowl changed and that leak stopped. If you don't mind me asking did you ask around for different prices. This info comes in handy when I need a part quick and know I can rely on the source. My tri-power has been in the shop for 6 months (resto)so I'm just gearing up for any mechancial ops when it comes home. Fuel system is one.
I've bought a lot from the same outfit also Summit. Just curious if their prices are better as the parts should all be the same MFR:. Thanks,grr#33570- Top
I tried ZIP first they had fuel bowls listed in their catolog but said they were discontinued.JEGS is a couple bucks more then Summit but they always deliver faster.I also found a web site for Parker carburetion that has very cheap Holley parts.I didn't know if I could trust them so I didn't order.Hope this helps! RICH- Top
