Re: Engine Block Protection while in Storage - NCRS Discussion Boards
  • Douglas C.
    • September 30, 1988
    • 230
    I have a bare engine block - no pistons, cylinder heads, etc., that is being stored on an engine stand. Is there anything I need to coat the cylinder bores or any other part of the block to help preserve it? Engine oil, or ?
    I expect to store it like this for about 2 years in my hot and often humid garage.
    --Doug, Member No. 13644
    • 15674
    I recommend you coat all machined surfaces with CJ-4 oil. Go to a HD truck supplier and get a quart of SAE 40 since it will have less tendency to flow down that the commonly available 15W-40. Use a paint brush to spread it on the surfaces - not dripping wet, but just like if you were actually painting it with enamel.
    Then cover it with a garbage bag but don't completely seal it so some air can circulate, and check it after a couple of months, then every few months if it's doing okay.
    High humidity is not necessarily a big problem, but condensing humidity can be. Any water droplets that form on uncoated iron in condensing humidity conditions will form minor rust spots.
    • Mike B.
      • November 1, 2004
      • 389
      You might also want to go to a marine store and get a can of spray storage oil for the internal passages. I comes with a straw and sprays a fog of oil that will stick to the surfaces.
      • Douglas C.
        • 230
        Thanks for the responses. I will follow-through with the advice.
        • Gary Schisler
          I am able to buy Fogging Oil at Advance Auto. No need to go out of your wary to purchase it.
          Gary
