master cylinder casting # - NCRS Discussion Boards
  • Don C.
    • July 31, 2005
    • 20
    The NCRS judging manual states the casting number for a 72 vett with power breaks is 5480346. A company that has ben licened by GM to manufacture these cylinders says the correct number is 5460346. What is the correct number?
    Thanks for your help!
    • 43221
    Re: master cylinder casting #
    don-----
    My belief is that the number is 5460346. I have checked this one out as best I could. I can't find any evidence that any part numbers in the "548" series were ever actually issued, although they were, apparently, assigned to Delco-Moraine.
      It's often difficult to tell a '6' from an '8' on embossed cast numbers. Curiously, the 68-69 and 70-72 NCRS JG books which have been revised several times reference the '548' sequence while the 73-74 and 75-77 JG's that're newer with fewer revisons call out '546'...
