1969 Corvette Lower Condenser to Dryer Pipe - NCRS Discussion Boards
  • Joseph M.
    • May 7, 2007
    • 65
    I'm looking for the part number for the AC pipe that connects between the lower condenser outlet and the Receiver / Dryer on a big block 1969 Corvette. I have everything else except for this pipe. Thanks!
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 1969 Corvette Lower Condenser to Dryer Pipe
    Joe, the 70 AIM shows no part number for that tube, which means it was supplied to the assembly plant with the condenser
    Further research in Doc Rebuild's catalog shows the lower tube as an integral part of the 69-72 condenser. If you have a tubing connector nut on the tube coming off of the bottom of the condenser, that tubing connector goes directly into the drier with an o-ring seal.
