Small guage bezel - NCRS Discussion Boards
Small guage bezel
  • Brad S.
    • July 31, 2005
    • 227
    Small guage bezel
    Are the 69 to 71 small guage bezels ( center dash cluster ) the same for A/C cars and non A/C cars with the exception of the vent insert or CORVETTE insert? thanks Brad
    • 43295
    Re: Small guage bezel
    Brad------
    I guess you could put it that way. However, the difference you described is quite a substantial difference. So, saying they are "the same except..." is a bit like saying that a Corvette and a Cadillac are the same except...
    • Brad S.
      • July 31, 2005
      • 227
      Joe, I guess I am asking if they will interchange if you change the upper insertwith the vent and wiper switch? thanks Brad
        • 43295
        Brad------
        They will physically interchange as far as being able to install them. However, There's no way that I can conceive of to convert one to the other as far as finished appearance goes.
          Guess, I'm missing the point...
          My copy of the '71 AIM pretty clearly shows the only change to center instrument cluster for AC cars versus non-AC equipped cars (Option Section, C60) is the insertion of the center duct assy, 3963792, and the air deflector bezel, 3946943, which replaces the base car's block-off plate. There's no mention of any other changes to the basic center instrument cluster. What am I missing in this thread?
          • Sal C.
            • December 1, 1984
            • 430
            Re: Guess, I'm missing the point...
            The gauge housing (or bezel) itself is the same for those years whether or not car has A/C. The difference is in the wiper switch housing inserts. The A/C version has vent deflectors, the non-A/C does not, but they both fit in the same bezel.
            • Brad S.
              • July 31, 2005
              • 227
              Thanks guys, Sorry if post was confusing. I have found a factory unbroken ( a rarity in itself) guage bezel out of an A/C car. My car is non A/C. Can I take the vent panel out and install my original block off panel in its place? I think Jack and Sal answered my question. Thanks
                • 43295
                Sal and Jack------
                Yes, you're both correct. For some reason, I was basing my previous response on my incorrect recollection of the configuration of the bezel. Some of the parts which I thought were part of the bezel are actually separate parts. The bezels for A/C and non-A/C are exactly the same.
