When I loosened the number 4 body mount bolts to install new fuel lines the captured nuts began spinning so that the bolt can't be backed out of the nut. I also noticed that the reinforcement is rusted around the hole the bolt goes through. I believe the cage for the captured nut is welded to the reinforcement. Is that correct? If so, it seems that the (painful) remedy for all this is to remove and replace the reinforcements, cages, and captured nuts. I've been through the archives and seen similar questions, but nothing exactly like this.
I had just put the car on the road after three years when the gas tank began leaking, so this is a big disappointment, but I think I may be off the road until next year. Any advice would be appreciated.
