Part # needed for 64 headlight switch - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    Looking for the correct Delco Remy part number for a 64 headlight switch.
    Any help is appreciated.
    Craig
  • M W.
    • July 31, 2001
    • 835
    If anyone has an original one for sale let me know *NM*
      Re: Part # needed for 64 headlight switch
      It should be called out in your copy of the AIM as Delco Remy 199531. A very common Chevy part at the scrap yards, Craig.
      Note the new banner on this web site asking us NOT to treat the DB as eBay with part solicitation(s)....
      • Wayne M.
        • March 1, 1980
        • 6414
        Here's what to look for
        Part # 1995131 lists for '64-65 Corvette and '65 Chev passenger. Note the "131" stamped in the bottom. On a Corvette you can easily see this by sticking your head under the dash with a flashlight. Also notice the form of the white ceramic on the top. I believe the "131" is the only one with this off-set "jog"; all the replacements have a much thicker section on the right side.
        They rarely pop up on eBay, which is where I got these 2 NOS examples --- Good luck.
        • M W.
          • July 31, 2001
          • 835
          My apologizes Jack. Thanks for the info. *NM*
          • Alan Drake
            Re: Here's what to do
            Note sure why you need a new one, however they do come apart, can be cleaned and returned to service. Just be careful when taking apart not loose anything.
            • M W.
              • July 31, 2001
              • 835
              Alan,
              There is no repair to my original one. I played tug of war with the headlight knob trying to get it out. Yes I have removed these many times before. Unfortunately for me I had two nearly identical knobs and the one I picked up was about 3/4" longer than the other and it was stuck. It took a bit of pulling and eventually it came out. Unfortunately, I broke the slider inside. I have already purchased a auto store repo while I search for an original one.
              Craig
