Finally got my frame painted and started the re-assembly, Are the front horn extentions, from the frame it's self, not the ones that go through the body by the grills, bolts black or plated?? 68 vette. How about the bolts that hold the transmission mount?
horn / trans bolts finish??
Re: horn / trans bolts finish??
The frame extension bolts and the transmission MOUNT bolts are black phosphate. The self-tapping bolts which secure the transmission shifter control bracket to the frame crossmember are cad or zinc plated.In Appreciation of John Hinckley- Top
Big Thanks, Do you recall which way they go. There's 3-4 of them. The ones with welded nut are obvious. Do they all point inward toward the motor? The reason I asked is because my parts car was raced and who knows which way that was assembled/ reassembled.- Top
