Is it possible for the carb to draw exhaust from the heat slot, if there is a pin hole in the carb gasket and transfer it through the clean air hose to the choke? If not, would it be possible for a back fire through the carb from bad gas to transfer carbon through the clean air hose to the choke? I have a 250hp, 3-speed early 62. Thanks in advance! Jon
