Door Weatherstrip lubricant - NCRS Discussion Boards
  • Oliver S.
    • December 1, 1999
    • 343
    Hello,
    what's the best for door weatherstrip lubrication:
    - silicon compound
    - glycerin
    - deer tallow
    - etc.
    Regards
    Oliver
  • Tom S.
    • March 1, 2004
    • 1087
    Re: Door Weatherstrip lubricant
    Silicone spray, put a little on a rag and wipe it on the weather strip. A little excess is o.k. and it will last quite awhile.Tom
    • Paul L.
      • November 1, 2002
      • 1414
      I have used this product for a number of years.
        • 15696
        Yes, liquid silicone lubricants work best. Apply once a year, and do it as part of your storage prep if you store your Corvette during the winter months.
        • Wayne K.
          • December 1, 1999
          • 1030
          Wurth Rubber Care is also good product. *NM*
          • Donald M.
            • December 1, 1984
            • 498
            Re: Wurth Rubber Care is also good product.
            I use GM Silcone Dielectric Grease (#12345579). Apply and "skim" it out to coat the weatherstrip. You can wear a surgical glove if you want, to spread the lube. I find it works great, especially on convertible weatherstrips to prevent door glass from sticking in hot weather. Lasts a long time since it more dense and will not evaporate.
            Don
            • Robert K.
              • June 30, 2001
              • 212
              All,
              What does the grease or liquid silicon do to the windows? Do you find that you continually need to wipe them off at the top where they make contact with the lubricant?
              • Gary B.
                • February 1, 1997
                • 7034
                Dielectric grease
                I also have used GM dielectric grease, based on Joe Lucia's recommendation, and I've been very happy with it.
                Gary
                • Gerard F.
                  • June 30, 2004
                  • 3806
                  How about this stuff
                  Works for me on Speedo/Tach cables too.
                  Comments?
                  Jerry Fuccillo
                  #42179
                  Jerry Fuccillo
                    • 15606
                    I have used all the above mentioned products at one time or another. All seem to work. I have settled in on Aerospace Protectant 303 lately. Less mess than silicone and easier application. 303 has more uses on the car also.
