Hi, I have two pairs of Trico RF-15 rubber inserts still in their original old boxes. However on two of inserts end, where the latch lock is located the very outside end of latch is stamped Pat Pend while the other old box of inserts are plain with nothing stamped on the outside of the latch lock. Other than that all four are the same, with the horizonal lines and patent numbers on the rubber. Which are correct for judging or are both acceptable ?
Thanks for your response,
dm
dm
