Regarding GM E.O.S., it was recommended to me to put a pint of this in with each oil change due to the changes in engine oil additives. The guy behind the parts counter at a local Chevrolet dealer confirmed that many are buying this and doing just that for the older engines. In reading the label on the back of the E.O.S. it says, "GM RECOMMENDS EOS ASSEMBLY LUBRICANT ONLY FOR THE SPECIFIC PURPOSES LISTED ABOVE. GM DOES NOT RECOMMEND THE USE OF THIS OR ANY OTHER PRODUCT AS AN ADDITIVE TO ENGINE OIL". It says all that in capitalized letters.
Is it ok to just pour this stuff in with the oil?
