Rear air shocks, original?? - NCRS Discussion Boards
  • Charles K.
    • May 31, 2006
    • 90
    I have 64 300 HP. The car is very unmolested which means the previous owners did little to the car. All of the suspension, steering components etc. appear to be factory. There is one odd thing, i notice that there are air lines to the rear shocks. My mechanic said that early Camaros had air shocks available. Could this be original? Also I ahve been thinking of replacing the suspension and steering components because they ar original. The car drives fine the way it is. Am I better off leaving it original or should I change shocks, springs, ball joints etc. Thanks for any help.
    Charlie ckrop@aol.com
  • Chuck G.
    • May 31, 1982
    • 2038
    Re: Rear air shocks, original??
    No original air shocks in any Corvette. Chuck
    • Rob Dame
      If it's not broke don't fix it.. JMO. Rob
      • David H.
        • October 25, 2006
        • 92
        Re: Why is there a hole behind liscense plate
        for pressure nipple?
        David Hobby (46447)
        • John D.
          • December 1, 1979
          • 5507
          Charles, Back in the 60's those air shocks were quite popular in the aftermarket. That's probably why the car has them. John
          • Clem Z.
            • January 1, 2006
            • 9427
            lot of owner put them on so drag slicks would clear and you would not have to cut the fenders
              • 43259
              Charles----
              I agree with all the others. No air adjustable shocks were ever originally used on a Corvette, either as standard equipment or as a factory-installed option. However, they could have been dealer installed. Delco did once have available air adjustable shocks for a Corvette.
              Also, I'm not aware of any use, standard or factory optional, of air adjustable shocks on Camaros, at least 1st generation Camaros.
              • Phil P.
                • April 1, 2006
                • 409
                nitrous re-charge orfice for small blocks *NM*
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  they were factory on some elcamino *NM*
                  • Gerard F.
                    • June 30, 2004
                    • 3806
                    I think they were standard on El Caminos
                    at least my 70 had them, and my 82 has them.
                    Jerry Fuccillo
                    • Bob E.
                      Infrequent User
                      • March 1, 1995
                      • 20
                      In Response To: I think they were standard on E
                      A friend of mine had a 1964 or 1965 El Camino back in the early 1970's that was equipped with factory air shocks. If I remember correctly, the air fitting was located on the package shelf behind the passenger seat with steel lines running up to that point.
                      Bob #25835
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        Re: I think they were standard on El Caminos
                        i had a new 71 and 72 and i was pretty sure they were there BUT that was a long time ago !!!! with snowmobiles and dirt bikes to haul i had to go to a full size pickups after that.
                        • Gerard F.
                          • June 30, 2004
                          • 3806
                          Re: In Response To: I think they were standard on
                          I think they put the air fill in different locations on different years. My 82 has it in the gas filler compartment on the driver side. If my memory serves me right, the 70 had it somewhere in the rear exterior area near the license plate.
                          Jerry Fuccillo
                          Jerry Fuccillo
                          • Steven S.
                            • August 29, 2007
                            • 571
                            I've owned two 66's and both of them had the old "Delco Pleasur-lift" air shocks on them. Very popular at that time.
                            • Gregory G.
                              • July 31, 2001
                              • 203
                              My '64 has the air inlet feed in the well behind the passenger seat.
                              Interesting.And mine is a low mileage original.
                              Aftermarket or GM Dealer installed?
                              Greg
