Truck block vs Corvette block - NCRS Discussion Boards
  • Gregory G.
    • August 31, 2004
    • 107
    I remember reading there was some small difference in the machine process between the corvette engine assemble and truch assembly plants. This is on a 1970 engine. Were there two different assembly plants? If so did they machine the blocks differently?
    Is there any notacable difference between a 4 bolt block from a truck vs corvette with the correct casting numbers and date code(not counting the stamp pad codes).
  • Harry Sadlock
    Re: Truck block vs Corvette block
    I heard a rumor long ago or maybe it was a joke that there were many yellow school buses that no longer had their 427 engines.
    If true, then there wasn't any difference.
    Harry
    • Don Y.
      • July 31, 2000
      • 166
      If you are speaking about the big-block engine as used in medium duty trucks they had a 0.4 inch taller deck height. The pistons used an extra ring in those applications and required more length of bore to compensate for this design difference.
      Don Yesacavage
      • John D.
        • December 1, 1979
        • 5507
        Greg, I had a new 68 BB and blew the engine with 48,000 miles on it. Luckily the warranty then was 50 thou. So the dealer put in a new block only and reused the old heads (valve job was extra) Anyhow on the back of the block I remember seeing Truck. I was told by the dealer back then that the block was the same as commercial use. But I am not up on the nitty gritty of C3's so don't know if this is true for us purists. John
        • Gregory G.
          • August 31, 2004
          • 107
          Re: Truck block vs Corvette block 350!!
          I am speaking of a small block block.
          • Gregory G.
            • August 31, 2004
            • 107
            What I remember hearing is something about a plug on the front that was needed at one plant to maching the oil gallery but not needed at the other. My CE block has the plug ( on the passenger side just above the timing chain cover) and so does a truck block I am looking at. Just wondering if the original installed engine has the plug or if there are any other differences. I do not want to waist time and money on a block that is not correct.
            • William C.
              • May 31, 1975
              • 6037
              Flint blocks (Corvette. Truck, and passenger car used the plug. Chevrolet Buffalo (Tonawanda) Truck, Car etc did not use the plug. If you have the plug you have a Flint block, and if the appropriate casting number is fine for Corvette use, suitably built.
              Bill Clupper #618
              • Tom S.
                • March 1, 2004
                • 1087
                Off the subject a little, but anyway I bought a brand new chevy C65 Tamdem axle dump truck with a 427 in for $16,100 in 1973. I thought that was a lot of money. You probably could not even but the dump bed for that today!And it was because I bought my first house in 71 for 12k !
                • Gregory G.
                  • August 31, 2004
                  • 107
                  I thought I heard something about the plug. Glad the block I am looking to pick up has it. Is this checked during judging? Bet not many know about this.
                  • William C.
                    • May 31, 1975
                    • 6037
                    Oh I think most Mech judges do... *NM*
                    Bill Clupper #618
                    • Dick W.
                      • 10483
                      Re: Oh I think most Mech judges do...
                      Clup, I have never looked, but were there still differences in the date coding between Flint and Tonawanda in the C-3 era??
                      Dick Whittington
