installing piston rings - NCRS Discussion Boards
  • Paul J.
    • June 30, 1999
    • 83
    Can anybody give me the proper location of ring gap on piston? My Sealed Power set for '61 230hp only shows views of oil ring. I need the location of first and second ring in relation to the oil ring. Thanks
  • John O.
    • May 31, 1998
    • 480
    Re: installing piston rings
    Hi Paul
    All I know is that each rings gap has to be 180 degrees from each other.
    John
    • Chuck R.
      • April 30, 1999
      • 1434
      90 to 180 degree stagger will work Paul. It's not all that exacting a science when it comes to this, but you just don't want them staggered too close.
      Make sure you feeler gauge the ring end gap in the cylinder bores as well if you haven't done so already.
      Chuck
      • Don Y.
        • July 31, 2000
        • 166
        Paul,
        Typically the top ring gap will be oriented at the top of the piston, as far away from the sparkplug as possible. The second ring gap will be oriented 180 degrees from the top ring gap.
        Don Yesacavage
          • 43221
          Paul-----
          An excerpt from the Chevrolet Overhaul Manual shows ring end gap positions:
          • Wayne W.
            • April 30, 1982
            • 3605
            Now, do yall think that those gaps stay where you put them or do they walk around. I cant imagine that they stay there.
              • 43221
              Wayne-----
              There's no way that they remain as originally set. However, I always set them as GM specifies, anyway. It's not that hard to do and, the way I figure it, it might not be beneficial but it can't be detrimental.
              • Allan J. Wicklund
                And, be aware that "End Gap" is critical to service life. Al W.
                  • 43221
                  Allan------
                  Yes, it's critical to lots of things.
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    NEVER put the end gap on the thrust side of
                    the piston
                    • Paul J.
                      • June 30, 1999
                      • 83
                      Thanks for the info. You guys are great. I love the forum.
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        they will move some,i have seen some with
                        the gaps in line,not every piston,at a tear down. this engine had some blow by but was not down on power that much
