1959 Corvette Brake Drum Part Number - NCRS Discussion Boards
  • Richard J.
    • August 31, 2005
    • 83
    Can any of you wise fellows tell me what the correct part number is for a 1959 Corvette brake drum is for both the front and rear. Thanks, Rick
    Rick Jones
    Albuquerque, NM
    Member #44319
    • 15657
    Re: 1959 Corvette Brake Drum Part Number
    I've done some research in this area, and beginning in '59 the base brake drum casting number was 3752623, and the finished base brake drum part number was 3752622.
    I don't have any info HD brakes or RPO 686 Metallic Brakes, however, the Metallic brake drum was probably the same casting number. The finished part number would have been different due to the finer surface finish required for Metallic Brakes.
    I wouldn't bet my life on this info, but it's the best I have for now.
    Hopefully others will chime in.
