I have a 1970 corvette with a CE short block dated 1971. To get back as many points as possible I am thinking of replacing my CE block with a block with the correct date code. I found a truck block with the correct casting number with a casting date within 3 months of my build date. This will also give me the opewrtunity to detail the engine and compartment.
I know this is very controversial but I am thinking of having the block decked and stamped with the correct numbers. According to the definition of COUNTERFEIT vs. RESTORATION under the judging rules I believe this is perfectly acceptable. I am not trying to pass my car off for something it was not, just trying to restore it to its original condition.
Does anyone know of a machine shop in the NJ/PA/NY/DE area that has the proper technique for milling to produce the proper broach marks and that can stamp it correctly? Can anyone supply me with the details on the correct stamp/fonts to use on a late 1970 350/350. I could also use guidence on the sequential numbers to use on the engine code that would match the build date and casting dates.
I remember reading about a book that was published that shows details of block numbers with photos. Does anyone know where I can get it. It is not listed in the NCRS store.
