Sorting out early big block valve springs - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    the L-88 springs are designed for .600 lift
    where the LS-6 spring is only good for .500 so the spring is designed differently
      • 43221
      Re: Sorting out early big block valve springs
      Duke-----
      I strongly recommend using the GM #3970627 "valve spring" on the 1966 L-72 engine. Actually, the 3970627 is a valve spring KIT. With every one of these I have ever purchased, it includes the valve spring (inner and outer) + retainer with integral "umbrella-type" oil seal. A complete engine set of the GM #3970627 "valve springs" is available under GM #12371061. However, I do not know if the engine set includes the retainer/oil shield components. I expect that it does, but I do not know that for a fact. IF you do need to order the retainers separately, order GM #3964264. These retainers definitely include the oil shield.
      The GM #3970627 "vale springs" are tried-and-true. After "blowing it" with the 65-69 springs, GM got it right with the 3970627. For a street engine, these are hard to beat.
      The 12371061 kit costs about $225, discount priced. I would use it rather than any other "equivalent" (which may or may not be actually equivalent).
