My '65 tire tub - NCRS Discussion Boards
My '65 tire tub
  • Ernest S.
    • August 31, 1990
    • 13
    My '65 tire tub
    I'm cleaning up my tire tub and lid, and was looking for part numbers, or
    stamped date codes. The only thing I could find was a manufacturer code (I think) molded into the fiberglass. It's laid out as follows :
    a 15/32"x 1/4" ellipse, with capital letters MFG inside of the ellipse.
    directly below are a row of 1/8" numbers 19146
    Is this the only number that can be found on mid-year tubs or lids???
    Ernie
  • Rob A.
    • December 1, 1991
    • 2126
    Re: My '65 tire tub
    Ernie...
    I believe those are the only markings actually molded in. The date stamp, if still visible, was an white ink.
    • Ernest S.
      • August 31, 1990
      • 13
      Re: My '65 tire tub
      Rob, Thanks for your input. While cleaning up my tub I found another similar
      molded in symbol and number. In the top of the tub, between the two rear
      mounting bolt holes it appears as follows:
      a 5/32" x 1/2" ellipse with 1/8" capital letters " MFG " inside, and directly below, 1/8" numbers 19154
      could not find any date code stamps, still not sure if these are
      manufacturer code numbers.
      Ernie
        Re: My '65 tire tub
        Ernie -
        "MFG" is the supplier - Molded Fiber Glass Corp., Ashtabula, Ohio.
        • Ernest S.
          • August 31, 1990
          • 13
          Re: My '65 tire tub
          John,
          Thanks for your reply. I can only assume now , that the numbers below the
          ellipse are part numbers.
          Ernie
