C3 AIR Pump Pulley Quiz - NCRS Discussion Boards
  • Tom R.
    • June 30, 1993
    • 4100
    What year AIR pump would you expect GM# 3932458 pulley to be bolted to? The letters are white and stamped onto the side of the pulley facing the radiator shroud.
    Last time I did this I got an internal error from the server...
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • 43222
    Re: C3 AIR Pump Pulley Quiz
    Tom-----
    I would say from late 1968 forward. I'm away from home right now so I can't determine the exact application.
    • Tom R.
      • June 30, 1993
      • 4100
      GM 3932458 is installed on a 78 pump with casting code 7817872 and date code 113081S. I had read somewhere that this pulley was unique to the early C3 years but that in later years...no stamps appeared on the pulley (78-79 manual). I have another I'm going to check...still on a 78.
      Tom Russo
      78 Pace Car L82 M21
      00 MY/TR/Conv
        • 43222
        Tom-----
        I'll check it when I get home. I'm sure it was used from about late 1968. However, it's still very possible that it was used into later C3's.
        • Tom R.
          • June 30, 1993
          • 4100
          MOst interesting because I think it will change some thinking on late model C3 tech team leader types...but then some are indifferent to the technical considerations for these years and therefore it becomes unremarkable.
          Tom Russo
          78 Pace Car L82 M21
          00 MY/TR/Conv
            • 15602
            Tom I have judged a lot of 1968-1972 Corvettes with AIR pumps installed -- looked at many more. I have NEVER seen a pulley (AIR or otherwise) with white letters. I guess I am missing something there.
            I have seen some in photos, where the photographer used chalk to enhance the numbers so they would be visible in the image.
            • Tom R.
              • June 30, 1993
              • 4100
              Terry:
              Don't lose perspective of where this thread began...it's less about 68-72 AIR pump pulleys and stamping and more about 78-82 AIR pump pulleys and what's stamped on those units.
              Tom Russo
              78 Pace Car L82 M21
              00 MY/TR/Conv
              • Tom R.
                • June 30, 1993
                • 4100
                Re: 3932458 Photo
                Here's image of pulley installed on a 78 AIR L82 pump
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                  • 15602
                  Well then I can say for sure I would NOT expect to see that pulley on a 1968-1972. While it might be the same number, the earlier pulleys were stamped the old fashioned way -- steel onto steel making impressions in the metal of the pulley.
                    • 43222
                    Tom------
                    The GM #3932458 AIR pump pulley was first used for 1969 Corvettes with L-46. That is the only application I can find through 1974. However, it was later used for all 1975-79 Corvettes with AIR and C-60.
                    The 1969 version of the pulley had the part number stamped into the metal. However, sometime during the 75-79 period, it appears that the stamping method changed to a white ink stamping. Just when that occurred I have no idea. My guess would be in the 78-79 time frame. That's about the time when some part number emplacements changed to ink-based methods.
                    The change to ink-based stampings has absolutely nothing to do with the part number or otherwise configuration of the part or the functionality of the part.
                      • 15602
                      "The change to ink-based stampings has absolutely nothing to do with the part number or otherwise configuration of the part or the functionality of the part."
                      Ah, but those pesky judges will focus on the style of the numbers stamp and mark their deductions appropriately.
                      • Tom R.
                        • June 30, 1993
                        • 4100
                        Re: In conclusion...
                        But than, late model C3 manuals were written with certain assumptions (the assumption being that it was done in 78-79 as previous model years) when the availability of data was scarce...the pulley is such a component. The 78-79 manual reports "no number" which I believe was a carry over from the 75-77 application of the pulley. We now know that indeed these pulleys carried the part number but printed with white numbers.
                        So all those following this thread now have the knowledge to distinguish the nuances of numbering stamping on a 68-82 AIR pump GM# 3932458 pulley. Thank you both for filling the knowledge gaps.
                        Tom Russo
                        78 Pace Car L82 M21
                        00 MY/TR/Conv
                          • 15602
                          Tom,
                          You will let the appropriate team leader in on what we all know so that the TIM&JG can be changed so that more than just those following this thread will also know, right?
                          • Tom R.
                            • June 30, 1993
                            • 4100
                            I'll send him a link
                            Tom Russo
                            78 Pace Car L82 M21
                            00 MY/TR/Conv
