C3 Starter Wiring - NCRS Discussion Boards
C3 Starter Wiring
  • Dale P.
    • September 30, 1995
    • 248
    C3 Starter Wiring
    Is there a small gauge(14?) black wire that mounts under the starter mounting bolts nearest the flywheel? I have a extra black wire that I can't figure out where it goes? Any help is very much appreciated.
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: C3 Starter Wiring
    Yes. Look at your wiring diagram. Its there in full print
    • Dale P.
      • 248
      Thanks...didn't have a true wiring diagram, was trying to work from memory.
      • Phil P.
        • April 1, 2006
        • 409
        could be outboard sratrter bolt ground wire *NM*
        • Kurt B.
          • July 31, 1996
          • 971
          On my 68, that wire mounts to the outer mounting bolt (one of the two that support the starter near the flywheel).
          I believe it is a ground wire
          Kurt
          • Wayne W.
            • April 30, 1982
            • 3605
            Ground for the fan motor and wipers.
            • Steven C.
              • October 23, 2006
              • 186
              What Wayne said...don't hook to starter *NM*
