66 A/C vacuum hose routing help - NCRS Discussion Boards
  • Ian S.
    • June 30, 2002
    • 264
    Hello,
    Could someone please look at the attached picture and give me an idea if the vacuum hoses coming off of the tee are routed correctly. I have followed what I could from the A.I.M and photos of my car before restoration but I am not sure how accurate it was. Car is a 327/300 hp a/c.
    Thanks in advance for your help,
    Ian
  • Ian S.
    • June 30, 2002
    • 264
    photo again *NM*
    • Kent K.
      • December 1, 1982
      • 1139
      Re: photo again
      Ian --- Your photo didn't show again. Preview your message first to see if it works.
      Kent Keech
      Kent
      NCM Founder - Member #718
      • Ian S.
        • June 30, 2002
        • 264
        Re: photo again
        Sorry about that, it showed up in preview both times. I have it on a different server now so I hope it works this time.
        • Mike G.
          • January 1, 1991
          • 418
          Re: photo again
          Ian: on my '65, the hose from the manifold fitting is going to the upper left tee nipple, and the line to the STV is on the bottom tee nipple. That's also how the AIM shows it in UPC C60, sheet E6.
          • Ian S.
            • June 30, 2002
            • 264
            Re: photo again
            Thanks Mike,
            I could sure use a photo of a car with this area routed correctly if anyone has one. I thought that the AIM showed the Manifold hose comming off of the passenger side tee also and then looping backwards and behind but when It 's done this way the loop sticks up high and seems out of place. I'm also not sure if the white striped hose going to the heater shut off valve is routed correctly also.
