Hello Everyone -
Need to replace my intake manifold gasket on my L-79.
Stock block and heads with an old Edelbrock high rise Aluminum manifold on it.
What do you guys like, Felpro?
Also -
1. use stock torque settings on the bolts?
2. put in new, replacement bolts when I do the change?
3. I get a little bit of oil seepage on the manifold bolts onto the manifold, do I put a little pipe dope on the upper parts of the threads when I put them back in?
Been about 30 years since I last did this, so I thought I'd double check with you all.
Thanks for your advise,
Rich
Also -
Rich
