C2 resistance - NCRS Discussion Boards
C2 resistance
  • Paul K.
    • February 1, 2002
    • 160
    C2 resistance
    I have a 66 that I like to push outside of the garage before i start it, Also has Bias ply tires. The problem is it pushes very hard,Has a lot of drag The parking brake is set correctly and does not interfear, the wheel bearings are adjust correctly. Is this normall or does something else need to be adjusted or fixed.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2 resistance
    This is common for these disk brake cars.
    • Gerard F.
      • June 30, 2004
      • 3806
      Re: C2 resistance
      Should not be. Check your parking brake or your brake calipers. My 67 is the opposite, will roll on any slight grade even with the parking brake on.
      But I need to redo the parking brake pads and assembly.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Jeff S.
        • July 31, 1984
        • 384
        Re: C2 resistance
        Paul
        Do you have the o-ring style pistons in your calipers? If so, these tend to have more rolling resistance than the lip seal variety.
        • Rob M.
          • April 30, 2003
          • 657
          Re: C2 resistance
          Paul,
          My 66 had basically the same issue and it turned out to be the master cylinder. It rolls just fine now with a new one.
          FWIW,
          Rob
          39795
          Rob
          '66 327/300 Regional Top Flt
          '08 6 speed coupe
          • Wayne K.
            • December 1, 1999
            • 1030
            Re: C2 resistance
            Paul,
            I'd jack one wheel at a time to check its resistance both before and after applying brake pedal. This show tell you if it is a particular wheel or wheels.
            Wayne
            • Brian K.
              • September 19, 2007
              • 174
              Re: C2 resistance
              Me too...new master cylinder & problem solved.
              66 Coupe
              66 Convertible
              2022 2LT Coupe
              67 Chevelle SS396
              67 XLCH HD Sportster
              • Paul K.
                • February 1, 2002
                • 160
                Re: C2 resistance
                Thanks for the info, Good advice.
                Paul
