C2:67 Help! Correct Fuel Line Size - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Steel fuel line to pump, 67 small block (300 HP), Part no. 3751442 per the AIM.
    Is it 3/8" or 5/16" flexible fuel line? also correct length? Paragons says 9" but it seems too short and makes a kink at the bend with 3/8"
    Using Gates XL line. Why do these fuel lines say "not for fuel injection".
    Are they OK for a carb car?
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
  • John D.
    • December 1, 1979
    • 5507
    Re: C2:67 Help! Correct Fuel Line Size
    Jerry, As far as your second question goes the Gates line will work fine for your low pressure carb line. I don't know for sure but think the modern FI cars need a line that will withstand more pressure. I buy that same hose and have used it on the old FI cars with no problem. But wait until the guru's chirp in. Ask the same question on your new venture. John
    • Gerard F.
      • June 30, 2004
      • 3806
      Problem solved
      Used the Goodyear SAE 30R7 in 3/8" (9.5 mm)from Kragens. However instead of using a 9" length, I used an 11" length. This gave it a little smoother radius bend without a kink.
      The old one just cracked out right on the outside of the bend and started leaking. Let's see how long this one lasts.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Brian M.
        • February 1, 1997
        • 1839
        Re: Problem solved
        If judging points are not a consideration I'd use the FI rated hose. JMHO
          • 15601
          Jerry,
          As John suggests modern fuel injection (the port type) runs at pressures sometimes as high as 60 psi. In these systems that pressure is generated at the pump, usually in the fuel tank, and carries all the way to the engine. The lines have to be able to take that pressure. The line you are looking at is not designed for those kinds of pressure.
