'62 Distributor hold down - NCRS Discussion Boards
  • Terry R.
    • March 1, 2005
    • 359
    I'm sure it's in the archives but I can't find it. '62 300HP Dist. hold down,stamped steel or wire? Thanks Terry Robertson
    • 43221
    Re: '62 Distributor hold down
    Terry-----
    I believe that it was stamped steel. 63-68 used the "wire" type.
    • John D.
      • December 1, 1979
      • 5507
      Terry,The 61-62 JM agrees with what I have been doing on FI restos.(applies to you also) 61 and 62 used the wire clamp. Quote from that manual: "All distributors are retained to the intake manifold with a bolt passing through a 1/8" thick formed steel retainer which in turn secures a clamp made of 1/8" thick rounded steel." Long explanation which which means wire clamp. They don't say what logo the bolt is though. Maybe someone will chirp in with a list of say 3 or so logos. I have seen UR's, etc. Be nice if the gang would voice their opinion on the retaining bolt.
      On the FI restos which I do I guess that I have covered this detail correctly.
      57 to 60 use the one piece stamped steel retainer and 61 thru 65 use the wire type. Hint: you have to read the JM carefully on this detail. Page 58 of the 5th edition. John
      • Terry R.
        • March 1, 2005
        • 359
        Mine is the wire type but the bolt has a M or W.I'm not real sure about how correct that is. Thanks Terry
