Replacement Ring And Pinion For C2 - NCRS Discussion Boards
  • J M.
    • July 31, 2005
    • 60
    My brother would like to replace the ring and pinion in his 65 with a set of 3:55's. Is OEM still available or must he go aftermarket as in a Richmond or other manufacturer? If aftermarket, will noise be a factor? Thanks.
    • 43221
    Re: Replacement Ring And Pinion For C2
    Dan-----
    All GM ring and pinion gearsets for 1953-79 Corvettes are long-since GM discontinued. You may find NOS on eBay or at swap meets, but you can't get them from a GM dealer.
    Several aftermarket brands are available. For a most-like-stock GM gearset, I recommend those manufactured by U.S. Gear. U.S. Gear does not sell direct nor inventory these parts. They manufacture to a minimum order size (large!) for gear retailers. One source that usually has these in stock is Tom's Differential (www.tomsdifferentials.com).
    • Gary R.
      • April 1, 1989
      • 1798
      As Joe said ,use Tom's gears. That all I use in my rebuilds, I've other brands and found Tom's( US Gear) setup and perform the best. Set the BL to 5-6 with these sets.
