C2 brake hose's - NCRS Discussion Boards
C2 brake hose's
  • Brian K.
    • May 31, 2004
    • 358
    C2 brake hose's
    Who makes the most accurate 66 vette disc brake hose's for maximium judging points?
    • 43240
    Re: C2 brake hose's
    Brian-----
    There are no hoses on the market today, including the GM hoses, that are identical or "close to the same" as hoses used for 65-74 Corvettes. The best that you can do is to be sure that the hoses have "ribs" as this is a glaring difference in some of the replacements. Otherwise, as far as markings, end fittings and crimps, none of the available hoses are similar to the originals.
    • Michael W.
      • April 1, 1997
      • 4290
      Re: C2 brake hose's
      Being that flex brake hoses are considered a safety item, I believe that there's a lot of leniency given for incorrect config during flight judging.
      • Mladen Bay
        Re: C2 brake hose's
        Even is someone wanted to reproduce the hoses, they will not be able to match the crimps, due to new safety regulations requiring a larger crimp.
