Hidden VIN? - NCRS Discussion Boards
Hidden VIN?
  • Lowell Maitland
    Hidden VIN?
    I've heard that the Corvette VIN is stamped somewhere on the frame and can't be seen unless the body is removed. Is this true? If so, exactly where is it located?
    Any insight will be appreciated.
    Thanks.
  • Mike E.
    • February 28, 1975
    • 5139
    Re: Hidden VIN?
    The answer is true--but will vary from generation to generation. What year Corvette do you have--we need to know that before we can give you much of an answer.
    • Stephen L.
      • May 31, 1984
      • 3158
      Re: Hidden VIN?
      These locations are on a 67 coupe frame:
      The one on the rear frame body mount #4 can possibly be seen using lights and mirrors.......
      The one under the door needs the body to be lifted above the frame for access
      • Lowell Maitland
        It's a 67 Coupe *NM*
        • Rob C.
          • August 31, 2004
          • 144
          Re: Hidden VIN?
          What about on a 72.
          Rob
            • 15606
            Re: Hidden VIN?
            1972 are under the driver's door sill and about over the rear axle on the driver's side. Same story about visibility as the 1967.
            • Rob C.
              • August 31, 2004
              • 144
              Re: Thanks *NM*
              • Frank C.
                • January 1, 1986
                • 277
                Re: Hidden VIN?
                I read the vin on a '67 my ex had with very little difficulty. I had to remove the rocker moulding and after a little wiping I found it with help of a mirror and light.
