Intake Manifold - Leave Alone ? - NCRS Discussion Boards
  • Mark H.
    • November 1, 2005
    • 112
    Hello,
    I'm in the final stages of a motor rebuild for a very original '65 (original everything except, now, the motor rebuild). Motor is now beautiful, but original intake manfifold is now ugly by comparison (it's orig, has a little orange over-shoot, etc)
    Anything wrong (i.e., worth of the car, etc) with me getting this beed blasted or some other clean up job, which will obviously take away from the original look ? I would think not since the motor is an obvious re-build. Thoughts ? Thanks
    please respond to mhontz@raytheon.com. At work and need to know asap.
  • David N.
    • June 30, 1991
    • 142
    Re: Intake Manifold - Leave Alone ?
    Mark, If you can post a photo of the as is condition, I am pretty sure that one of the mid-years owners will be able to help you out. Of course they could do that without a photo but, I thought it might be good for us to know its present condition. A photo of the rest of your engine rebuild would be a bonus, too.
    Just my thoughts,
    David Nims
    19639
    • William C.
      • May 31, 1975
      • 6037
      A assume you are takling about an aluminum intake. DO NOT bead blast it under any circumstances. There are a myrad of ways to clean it using chemicals, but bead blasting will remove the original surface finish that was created during the molding process and is a permanent alteration to the surface. Soap, water, aluminum door cleaners and the like are all better (if more tedious) options than the blaster.
      Bill Clupper #618
      • Joe C.
        • August 31, 1999
        • 4598
        Send it here.....I assume you're talking about an aluminum intake.
        Joe
        • Jim S.
          • March 1, 1986
          • 1402
          I second the motion to sent it to Jerry MacNeish . Looks great , fast turn arround , and not too expensive!
