My painter died on me - NCRS Discussion Boards
  • Andy Anderson
    Looking for a painter not a paint job in Houston Texas area. I am looking for a experienced lacquer painter with paint booth and references.
    My 60 vett. body has been removed from the frame and is on a big wheel steel car carrier. Striped of all parts. Paint has been soft striped off. All body work done,( two 1 inch cracks in right fender area and a 4 inch area under the left bumper). all pin holes filled for the soft striping. Premiered with 3 coats of ppg k-36 primer and block sanded. Premiered again with 2 coats of k-36 and 600 wet sanded. Motor compartment painted and taped off. finder wells painted and tape off. side cove painted and taped off. Doors, trunk, hood, top lid, and any body part that could be removed has been removed. I have the lacquer paint and thinner. All I want is it sprayed. I will do the sanding and compounding. If you or some one you know is interested. please e-mail me . Thanks C. A. Anderson Rt 2 Box 717 #4 Pine Oak Cr. Dickinson Texas, 77539 andrew2@freewwweb.com
