71 MASTER CYLINDER - NCRS Discussion Boards
71 MASTER CYLINDER
  • Richard B.
    • May 31, 1984
    • 37
    71 MASTER CYLINDER
    COULD SOMEONE PLEASE TELL ME WHAT OD1 AND 9301 MEAN ON A 1971 MASTER CYLINDER
    THANK YOU
    • 43241
    Re: 71 MASTER CYLINDER
    Richard-----
    If you are referring to CASTING marks (i.e. characters that are created by the pattern/mold when the part is cast), I don't know that anyone has figured out definitively what they mean. They often vary widely from one casting to the next. I have not noted the "OD1" you describe on original Delco-Moraine castings. However, I don't doubt that it may be on some. If the master cylinder is a "509" casting, it may refer to the fact that it's designed for a 1" finished bore size. All 1971 Corvettes with manual brakes used a 1", "509" master cylinder.
