BB Rods Torque Spec - NCRS Discussion Boards
BB Rods Torque Spec
  • Markus Joerg
    BB Rods Torque Spec
    I'm looking for the torque specification of the LS-6 Connection rod GM 12496661. It has 7/16 bolts.
    thanks
    Markus
  • Big Block George
    70 Ft. pounds........
    no more, no less. Using new bolts or ABUB (Already been used bolts)? Suggest you get new ones.
    • motorman
      Re: BB Rods Torque Spec
      be sure to oil the threads and rod surface where the nut makes contact with 30 wt motor oil.
      • Big Block George
        ....or Moly lube....................
        is even better
        • motorman
          Re: ....or Moly lube....................
          i would be careful using moly kote as it changes the coefficient of friction and you will get a higher torque on the bolt for the same reading than you do with oil. i tried molykote on main studs one time and although i had not reached the rated torque on the stud it broke off in the block and i had to make a drill jig/fixture to drill it out. always check what lube they recommend for a stated torque value.
          • Big Block George
            I seriously doubt moly lube the cause.......
            of the broken stud, but rather a weakened or fateaged stud. ARP includes a package of Moly lube with every rod bolt, head, & main stud package.
            • motorman
              Re: I seriously doubt moly lube the cause.......
              their torque specs are set for the use of molykote. most torque specs in chevy books are for oil. crower rod bolts spec oil for lube but carrillo supplies a moly based lube but for the same size rod bolt the torque spec is different. there is more bolt stretch on the same bolt using the same torque when using moly kote vs motor oil. i have tried this on rod bolts using my rod bolt stretch checker. JMHO
